RSPAN woes
stephen.baugh
I have just set a RSPAN vlan and some ports to monitor but dont seem to be receiving any IP traffic. I can see the MAC addresses of hosts im trying to monitor across the RSPAN vlan.
Any ideas ?
Cheers
switch with sniffer connected
Session 1
Type : Remote Destination Session
Source RSPAN VLAN: 900
Destination Ports : Fa0/32
Encapsulation : Native
Ingress: Disabled
switch with hosts trying to monitor
Rspan Type : Source
Destination : -
Reflector : Port 2/48
Rspan Vlan : 900
Admin Source : Port 2/2
Oper Source : Port 2/2
Direction : transmit/receive
Incoming Packets: -
Learning : -
Filter : -
Status : active
6 Replies 6
Edison Ortiz
Can you post
show run | i monitor
from each switch ?
Stephen
Is there a trunk configured between the switches that is configured to carry VLAN 900? There needs to be a trunk between the switches for the RSPAN VLAN.
Rick
Rick
Hi Rick
VLAN900 is allowed accross the trunk, I can see the MAC address of the host im trying to capture.
config as below
Host monitor switch
#switch port analyzer
set rspan source 2/2 900 both reflector 2/48 create
Switch with Sniffer connected
monitor session 1 destination interface Fa0/32
monitor session 1 source remote vlan 900
Stephen
Thanks for the additional information. Perhaps you can also post the configuration of the trunk on both switches. It might also be helpful if you would post the output of show trunk on both switches.
Rick
Rick
Outputs for show trunk
Switch with sniffer connected
Port Mode Encapsulation Status Native vlan
Gi0/1 on 802.1q trunking 1
Gi0/2 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/1 1-4094
Gi0/2 1-4094
Port Vlans allowed and active in management domain
Gi0/1 1,10-11,40,50,900,999
Gi0/2 1,10-11,40,50,900,999
Port Vlans in spanning tree forwarding state and not pruned
switch with hosts
2/49 on dot1q trunking 1
2/49 1-1005,1025-4094
2/49 1,10-12,15-16,20,50,60,90,102,230,900
mpc
Do you have the VLAN 900 defined as "remote-span" ?
IE:
switch(config)# vlan 900
switch(config-vlan)# remote-span
Also, RSPAN on 2950 supports either Tx or Rx, but not Tx/Rx together for some reason.
P.
