Community Member
RSTP
What is the convergence time for RSTP and how does it converge.Let me know how to configure PVST in the segmented LAN switching environment
Cheers
Bava
1 REPLY
Re: RSTP
Bava
I strongly recommend you read up the below links.
convergence for RSTP is in the order of seconds. (I had 16 switches in a ring, and converged in less then 3s).
http://www.cisco.com/en/US/docs/switches/blades/3030/software/release/12.2_37_se/configuration_/guide/swmstp.html
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a00807b0670.shtml
if you are forecasting to have many VLANs, then go for MSTP which will enable RSTP. but i you will only have fewer, then you may choose to configure R-PVST.
Pls rate all helpful posts.
Sam
135
