Running NBAR protocol discovery on Switches
mistryj
How do I enable ip nbar protocol discovery on Cisco 6509 OS version Version 12.2(18)SXF ? would like to do this to get some stats on current traffic running on our network.
I have CEF enabled already but do I need any other commands so I can enable nbar on an interface. At the moment only global command exist for nbar and not interface command.
Switch(config)#ip cef ?
accounting Enable CEF accounting
distributed Distributed Cisco Express Forwarding
event-log CEF event log commands
interface CEF linecard commands
linecard CEF linecard commands
load-sharing Load sharing
nsf Set CEF non-stop forwarding (NSF) characteristics
table Set CEF forwarding table characteristics
traffic-statistics Enable collection of traffic statistics
Global Command (No Interface Command ?) :-
Switch(config)#ip nbar ?
custom Custom PDL (protocol description language) Module
pdlm PDL (protocol description language) Module
port-map Map well-known port of a protocol to a new port
resources Configure memory usage for tracking Stateful sessions
Edison Ortiz
Joseph W. Doherty
Most switches don't support NBAR. For the 6500, believe some of the WAN module cards do (e.g. FlexWAN, SIP-200/4000), or there's somewhat of a similar capability(?) if using a sup32-PISA.
So 6500 with Sup-720 wont work either ?
What can I use to classify traffic for QOS ?
I thought using nbar would help greatly with minimal cost ?
You can use ACLs.
For instance, for match protocol http, you can do the same with:
access-list 101 permit tcp any any eq 80
access-list 101 permit tcp any eq 80 any
class-map NETPRO
match access-group 101
While the 'match protocol' command is available under the 6500 Sup-720 CLI, activating that command will produce sub-par performance as that process will be running in software.
HTH,
__
Edison.
