Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
S O S f?d?rator switch Catalyst 3750G-24TS-S Failure
We are encountering a failure of our federator switch a catalyst 3750G-24TS-S
The startup output on console port is as follow in the attached file
Our network is down (no communication between floors)
Can anybody help us, this is an emergency.
Silver
Re: S O S f?d?rator switch Catalyst 3750G-24TS-S Failure
Hi ,
It is better open a TAC case with cisco to resolve the issue because traceback is present in logs which can be decoded by TAC engineer for seacrhig for known issues.
satish
I have only guest level acces and cannot use TAC.
I need to know if it is hardware or software problem
please help us
bjw Silver
Silver
A POST ASIC failure is pretty much always a hardware failure. It's the lowest level hardware diag (Power on self test)
The failure is indicated as follow :
POST: PortASIC CAM Subsystem Tests : End, Status Failed
Is the portASIC CAM Subsystem a replaceable component or does the switch have to be replaced.
Thanks for answering.
Hello, I'd like to know how have you fixed this problem. Thanks, Douglas.
184
