Community Member
save in form automatica running-config in tftp
I need to know how can I to put command with WR to save in form automatic the running-config of the switch 3750 but the save will have a TFTP o FTP.
The TFTP will have running-config as backup Anyone can help me?
1 ACCEPTED SOLUTION
Community Member
Re: save in form automatica running-config in tftp
Under config terminal create a macro
#macro name BACKUP
Type in:
do wr me
do wr network tftp:
@ (to end it)
Launch the macro by going into config terminal and type:
#macro global apply BACKUP
Community Member
#macro name BACKUP
Type in:
do wr me
do wr network tftp:
@ (to end it)
Community Member
hello thanks for reply, I have other question how can I do this but for catalyst 6500 in IOS?
Can you help me?
Community Member
I'm not sure that macros are supported on 6500 IOS
146
