SDM on catalyst 2950
Antonio Brandao
Why informations about Switch Health and Port Utilization on dashboard in SDM software doens't appear ?
info >>
swtich : catalyst 2950
ios image : c2950-i6q4l2-mz.121-22.EA9.bin
Att
Antonio
9 Replies 9
carenas123
Level 5
Level 5
Cisco Router and Security Device Manager (SDM) is a tool that can be used to proactively manage Cisco IOS software-based router resources and security before they affect mission-critical applications on the network. Security Manager provides the ability to start SDM without the need for SDM to be installed on your router.
Thanks Carenas, for your reply,
Correcting....
the correct software is the cisco device manager for switches and don't SDM how i had mentioned..
...so why the dash board information doesn't appears ?
What can be my problem ?
At
Antonio
I have the same problem.
Did you figure it out?
Please let me know if you have a solution.
Thank,
Zeek
Leo Laohoo
2950 and SDM???? 2950 can't accomodate the SDM software. Are you talking about the Cisco Device Manager?
3650... non of the switches with the web interface shows traffic on the ports.
I've tested in 10 of them.
Use 3rd party software, like Solarwinds. It's more accurate and you can create a report.
what app from solarwinds?
free?
let me know.
I used to use a software called CyberGauge (by Neon Software). The company was bought by SolarWinds in 2006.
is it free?
can you provide the link please?
thank you
