SDM Problem
wasiimcisco
have cisco rouer 3825 but unable to access via SDM. Please see the configuration in attachement. i tried with https, http and via SDM loaded. getting page cant be displayed.
Please help me out
5 Replies 5
Mark Yeates
Level 7
Level 7
Try adding the "ip http timeout-policy idle 60 life 86400 requests 10000" command. Assuming that you can ping the router, and SDM is installed correctly things should be working.
Mark
i applied the commands but still not result
belwo is output of flash
sh flash
-#- --length-- -----date/time------ path
1 38373256 Jun 3 2008 16:17:14 +00:00 c2800nm-advipservicesk9-mz.124-18.bin
2 1826 Nov 5 2007 14:30:04 +00:00 sdmconfig-28xx.cfg
3 6036480 Nov 5 2007 14:30:36 +00:00 sdm.tar
4 861696 Nov 5 2007 14:30:52 +00:00 es.tar
5 1164288 Nov 5 2007 14:31:10 +00:00 common.tar
6 1038 Nov 5 2007 14:31:28 +00:00 home.shtml
7 113152 Nov 5 2007 14:31:46 +00:00 home.tar
8 527849 Nov 5 2007 14:32:02 +00:00 128MB.sdf
9 1697952 Nov 5 2007 14:32:24 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
10 416354 Nov 5 2007 14:32:46 +00:00 sslclient-win-1.1.3.173.pkg
14802944 bytes available (49213440 bytes used)
Can you ping the router, and the router ping your PC?
yes everything is working fine, this is my internet router, telnet is working, i m managing it via telnet, only SDM is not able to load.
What web browser are you using? Do you have java installed. There are some issues with Vista/IE7 with allowing active content to be ran. Check out this post.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=WAN%2C%20Routing%20and%20Switching&topicID=.ee71a06&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbf4f53
Mark
