secondary ip address
how to see configured secondary
ip address in interface?
Re: secondary ip address
Hi there,
You should be able to see any configured secondary IP addresses under the interface configuration, either by running a show run of the whole config or by simply running show run interface x/x.
Example:
show run interface fa0/0
ip address 172.23.1.1 255.255.255.0
ip address 172.23.2.1 255.255.255.0 secondary
Hope this helps,
Jonathan
if you do not know the interface number and you dont have the priv for show runn command for viewing the running config, still you can use show interface and you would be able to see all the interfaces in the Router.
329
