Secondary SUP720-3B state-unknown/other.
I have 6509 with dual sups, the secondary sup has failed and I am not able to bring it up even after reboot. the state says unknown/other. Does anyone know what that state" unknown" means?. I could not find any documentation about this state.
Actions performed: 1) Reboot 2) Re-seat the module.
Here is the output of the show module on 6509
router#sh module
Mod Ports Card Type                              Model
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
  6    2  Supervisor Engine 720 (Other)          WS-SUP720-3B
Mod    MAC addresses                                  Hw    Fw               Sw           Status
  5      XXXX.YYYY.ZZZZ to XXXX.YYYY.ZZZP   5.6   8.5(2)           12.3(26)       Ok
  6      XXXX.YYYY.ZZZZ to XXXX.YYYY.ZZZP   5.6   Unknown      Unknown      Other
Mod  Online Diag Status
  5     Pass
  6     Not Applicable
Any help is appreciated!!
Thaks/Blach
1 ACCEPTED SOLUTION
VIP Super Bronze
Hi Blach,
Yes, the primary sup does not see the stand-by at all.
Can you console to the stand-by Sup and make sure it boots completely?
Also, once booted, can you check to make sure you are running the same exact IOS on the stand-by and if there is any crash file on the flash?
VIP Super Bronze
Can you post the output of "sh redu"?
Hi Reza, Thanks for your response.
Here is the output of the show redundancy
sh redundancy
Redundant System Information :
       Available system uptime = 16 weeks, 8 days, 16 hours, 14 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Simplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
              Maintenance Mode = Disabled
                Communications = Down      Reason: Simplex mode
Current Processor Information :
               Active Location = slot 5
        Current Software state = ACTIVE
       Uptime in current state = 16 weeks, 8 days, 16 hours, 14 minutes
                 Image Version = Cisco IOS Software, s72033_rp Software (s72033_
rp-IPSERVICESK9_WAN-M), Version 12.3(26)SXH3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 24-Sep-08 07:29 by prod_rel_team
                          BOOT = disk0:/s72033-ipservicesk9_wan-mz.123-26.SXH3a.
bin,12;
                   CONFIG_FILE =
                       BOOTLDR =
        Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED
' state
VIP Super Bronze
Hi Blach,
Hall of Fame Super Gold
Looks like the secondary Sup has the wrong IOS.  The active Sup can see the hardware (hence you get the HW version) but can't see the FW.
The standby supervisor needs to boot to a certain point before the software can communicate with the active. Typically the unknown state is seen when the standby supervisor is in ROMMON. You need to get on the console of the standby and try to boot the supervisor manually.
1865
