Security ACL with Syslog
Does anyone know how to send the denied statistics to a syslog server for a security acl? I am using -- set security acl ip IPACL1 deny tcp any any eq 135 log -- on the switch. When I run -- show security acl log flow tcp any any -- I see entries but they are never sent to my syslog server. I set the syslog server facility to 5. Any suggestions?
Re: Security ACL with Syslog
you should set logging to the appropriate level based on the message...ex)
%SEC-6-IPACCESSLOGP
Set logging to level 6 in this instance
you would also want to enter the command:
logging
Are any other syslog messages making it to the syslog server? If not, then it isn't set to reach the server correctly.
Syslog server is getting information about ports connecting and disconnecting.
I set the level to 6 and i will check syslog.
thanks
134
