Segment from PIX to segment on ASA
Tyler Woods
I need the following to happen:
Host at 12.x.x.134 to access host 10.50.2.32 on port 8888.
Host at 12.x.x.134 to access host 10.50 2.33 on port 1560.
I am at a complete loss on getting this accomplished. Have tried multiple configurations and nothing works. Ideally I would collapse this all to the ASA but I do not have the time to dedicate at the moment so I just need to get this working as it is. The ASA is under SMARTnet but CCO ID does not have permission to its serial number yet.
Any guidance on this would be greatly appreciated. Is below enough to go on?
ASA Interfaces
Ethernet0/0 outside 64.xx.xx.130 security-level   0 --> to RouterA via 2980
Ethernet0/1 inside  10.50.2.1    security-level 100 --> to 2980
Ethernet0/2 dmz1    10.10.10.2   security-level  50 --> to ASA e2
PIX
Ethernet0   outside 12.xx.xx.2   security-level   0 --> to RouterB via 2980
Ethernet1   dmz     12.x.x.129   security-level  50 --> to 2980
Ethernet2   dmz2    10.10.10.1   security-level  50 --> to PIX e0/2
So we need the pix traffic from 12.x.x.x to go  out via the pix outside interface and in via the ASA outside interface to get to to 10.50.2.x. Is this possible to setup ?
Jon
63 Replies 63
Jon Marshall
Tyler
So to get to the 10.50.2.x network from the pix you have to through the ASA. Is this correct ?
Also what version of ASA code are you running - hopefully less than 8.3 or whenever they changed all the NAT code
In addition if the traffic does go from the pix through the ASA does the pix have routing for the 10.50.2.x network and does the ASA have routing for the 12.x.x.x network ?
Jon
ASA is on 8.2(5) and the PIX is on 7.0(6)
Yes, 10.50.2.x exists on the ASA and 12.x.x.128 exists on the PIX. I know there is a combination of ACL and possibly NATs I just haven't nailed the right one. Interface dmz cannont ping 10.10.10.2 on the ASA yet I can ping 10.10.10.2 from the PIX if I don't specify an interface. I put a route on the PIX sending any request for the 10.50.2.x network to 10.10.10.2 because that should be it's next hop unknown to the PIX for that network I would think.
Note - before making any changes you need to check existing config to make sure you are not overriding anything else.
ASA
static (inside,dmz1) tcp 10.50.2.32 8888 10.50.2.32 8888
static (inside,dmz1) tcp 10.50.2.33 1560 10.50.2.33 1560
if there is no route for the pix 12.x.x.x network you will need one ie.
route (dmz1) 12.x.x.0 10.10.10.1
you will also need an acl entry allowing the traffci eg.
access-list dmz1 in permit tcp host 12.x.x.134 host 10.50.2.32 eq 8888
access-list dmz1 in permit tcp host 12.x.x.134 host 10.50.2.33 eq 1560
if there is already an acl on the dmz1 interface applied inbound obviously add to that rather than create a new one.
Pix
The security levels on dmz and dmz2 are the same so traffic should flow freely but this is dependant on whether or not you have "same-security-traffic permit inter-interface enabled" in the config of the pix. If yo do you do not need acls or NAT but you may want to control traffic between those interfaces o you may be using nat and or acls.
So it's a question. I'm not suggesting you enable or disable it without further info because obviously this could have  big impact on other traffic.
Jon
I had everything in there except for the NAT statements.
The "same-security-traffic permit inter-interface" is in the PIX so I'm not going to touch that. I just inherited all these networks months ago so just wrapping my head around everything at the moment. I attempted a route statement like you suggested on the ASA for 12.x.x.0 access and it broke things last time. Currently as far as I can tell traffic to that network is covered by the default and taken care of by one of the routers.
I have an ACL applied to interface dmz1 like this: access-group DMZ2IN in interface dmz1
Just go word they are still blocked.
If that's the case then what i gave you won't work. If the pix sends traffic to the ASA direct for 10.50.2.x but the return traffic goes via another interface on the ASA and enters a different interface on the pix then we need to trace the full path. So if you cannot add a route to the ASA for 12.x.x.x via the pix then we need the pix to send traffic for 10.50.2.x via a different path ie. via the router the ASA uses.
So can you trace the full path for me ie. ASA 10.5.2.x to pix 12.x.x.x and then we can go from there. Note that the pix will have to send traffic back the same path so it arrives on the correct ASA interface so that route on the pix will need removing. The acl entries and NAT entries i gave will also need removing as they are  not doing anything.
Jon
Yes, sorry I didn't mention the route before. When I started trying to get this working for the site I thought the way things are routing currently would cause problems.
So tracing from the 10.50.2.x network it leaves the ASA outside interface, to the Internet, then comes in the PIX outside interface.
Jon
Didn't mean to hit the correct button.
To be honest I have no idea. I don't think so if I'm understanding this correctly. In my mind it makes more sense for 10.50.2.x traffic destined for 12.x.x.x/27 to go from the ASA directly to the PIX and not outside. Like I said when I did a route stating that it broke a lot of things and I'm still not understanding why. I'm in the process of sanatizing my configs now to post at r/cisco.
I agree it would be easier to simply get the traffic to go direct. Bear in mind 12.x.x.x addressing is actually valid internet addressing. Have these addresses been assigned to you. I would have though it unlikely as they are class A addresses. If they haven't maybe that explains part of what went wrong.
Jon
Yes, I do realize they are valid Internet addresses. We have a range given to us by our ISP. These have been in place for quite some time as I understand it.
If the full configurations will help here they are.
ASA: http://pastebin.com/raw.php?i=EfgnGQF9
PIX: http://pastebin.com/raw.php?i=QenykNkm
I feel like I understand the big picture in how this should be setup but implementing this is clearly got me stumped. Still working my Cisco rep to get the serial number for the ASA under my CCO loging so I can open a ticket for configuration assistance.
Thanks for the configs.
Can you remember what broke when you added the route to the ASA ?  If we could sort that issue out i think we could go with the original solution and it would work fine.
Jon
Users on the 12.x.x.x segment lost access to the Internet. For all I know I put the route in wrong. I could have swore I put something like this:
route inside 12.x.x.x 255.255.255.224 10.10.10.1
10.10.10.1 being the interface on the PIX connected to the 10.10.10.2 ASA interface.
Couple of things -
the route should be -
route dmz1  12.x.x.x 255.255.255.224 10.10.10.1  ie. the interface should be dmz1 and not inside
the other thing is that you are also using 12.x.x.x addressing on your outside interface of the pix. Is this is a different subnet ie. you are definitely not overlapping are you ?
Jon
