sending mail problem
Hi all,
I have the following problem: My customer has a mail server at their site. They are using Alt-N Mdaemon Pro for Windows mail server, cisco 837 ADSL router. Recently, they reported that they can receive email from outside but cannot send mail outside. However, when I change Cisco 837 by a Linksys router, the local mail server can send mail outside.
I have tried to remove all ACL on the router, ADSL connection is ok but still cannot send mail outside. This is my router configuration:
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxxxxxxxxx
enable password xxxxxxxxx
no aaa new-model
ip subnet-zero
no ip source-route
no ip domain lookup
no ip bootp server
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
ip subnet-zero
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.250 192.168.1.254
ip dhcp pool xxxxxxxxxxx
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 203.162.x.x.162.4.191
update arp
interface Ethernet0
description <xxxxxxxxxxxxxxxxx>
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc ATM0.1 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
description <Connection to Internet via ADSL>
bandwidth 640
ip address negotiated
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username xxxxxxxxxx password xxxxxxxxxxxxx
ip nat inside source list 1 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 1 permit any
access-list 1 remark The local LAN.
dialer-list 1 protocol ip permit
line con 0
exec-timeout 120 0
password xxxxxxxxx
login
no modem enable
stopbits 1
line aux 0
line vty 0 4
exec-timeout 120 0
login local
scheduler max-task-time 5000
end
Can anyone help me to isolate/fix this problem? Thanks in advance.
Re: sending mail problem
Can you try configuring the below commands under your dialer interface ?
ip mtu 1492
ip tcp adjust-mss 1452
regds
spremkumar,
Thanks alot. It works right now. So there is no default setting for maximum segment size (MSS) value of TCP SYN packets, right?
regards,
I have seen quite a few issues inline with the MSS and MTU sizes especially when it comes to DSL/ADSL connectivity.
AFAIK the default size of MTU would be 1500 bytes which comes with most of the interfaces which i feel required to be tweaked in case of these kida connectivity issues.
Usually the MSS will be 40 bytes lesser than the normal mtu which u define under the interface..thats the thumb rule being used at present ..:-)
regds
159
