Community Member
Serial cable connection
I try to connect two Cisco 2504 router together with DCE-DTE cable at serial 0 at both side. However, it is not work, when i try to use serial 0 and serial 1 at each side. it works again.
What is the problem ?
Re: Serial cable connection
Can you configure "clock rate" on the DCE side and see if that helps ?
Community Member
i try to configure the clock rate at DCE side and it is still not work
I have a couple of questions:
1) Is the S0 in working condition?
2) Are the ports in "no shut" state ?
In addition to that can you check whether you have the command 'frame-relay intf-type dce' on the DCE interface.
Sundar
Community Member
all the setting as following
ip address
subnet mask
working condition
all both two port have setting probaly
however, when i use s0 to s1 with same setting it works not in s0 to s0
can you post the configs on both ends when you are using s0 and s0 AND so and s1.
What do you mean by working condition. Is in the interface in up/down state. What is the status of the interface signals, DCD/DTR etc. Can you post the relevant configuration?
Sundar
Community Member
2501>show int s0
Hardware is HD64570
Internet address is 192.168.1.2/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output 00:00:06, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
29 packets output, 638 bytes, 0 underruns
0 output errors, 0 collisions, 11 interface resets
33 carrier transitions
Serial0 is up, line protocol is down
Hardware is HD64570
Internet address is 192.168.1.10/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input 00:00:09, output 00:00:00, output hang never
00:11:28: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to downd/drops)
40 packets input, 880 bytes, 0 no buffer
Received 40 broadcasts, 0 runts, 0 giants, 0 throttles
104 packets output, 14034 bytes, 0 underruns
0 output errors, 0 collisions, 26 interface resets
28 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
It would be easy to troubleshoot if you can provide more info.
Could you post the
1) "sh run" for interfaces s0 and s1 on both the routers you are connecting?
2) "sh interface" for s0 and s1 for both the routers
163
