11-19-2006 07:04 AM - edited 03-05-2019 12:54 PM
dear sir,
Please advise how to get the serial no. of gbic module without pull out the gbic hardware physically because it's live in production. Based on the show tech-support, can we get it? Hereby attached the show tech-support. please helps.
thank you very much.
11-19-2006 09:20 AM
Are looking for the serial number of the 6 port GBIC modules place in Slot 4 and 5. If yes, here are the serial numbers :
Slot4 module : JAE0438053H
Slot5 Module : JAE043901TG
If you are looking for the GBIC interface modules plugged into these module, then I wonder you cannot get it ftom the " Show tech ". You are running a very old CatOS on the switch and I think you will not even have command to take that out form the software.
You have to physically take it out fronm the module to check it.
-amit singh
11-19-2006 10:18 AM
hi amit singh,
I am looking for the serial no. of GBIC interface modules plugged into the module.
So we must plug out only we can get the serial no.
11-19-2006 05:02 PM
There is no way to get that info on a catos box that I know without pulling the gbics out .
