10-10-2006 01:20 AM - edited 03-05-2019 12:09 PM
If I dont put an ip address on my serial, what will it/not do ?
10-10-2006 03:44 AM
It will not do IP processing. However if you want IP processing to be done on serial interface without using IP address use IP unnumbered command
10-10-2006 04:41 AM
so will the interface not be able to operate with no ip address ?
10-10-2006 05:04 AM
if u dont put petrol in your car what will happen it will not run so its simple the router will not be able to route or communicate.......but it can be possible still not putting ip address but can make it work its with ip unnumbered command.....
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8d.shtml
its a v goo dlink for understanding it cheers and rate all post plz
