Webcast-Catalyst9k
serial, no ip address
If I dont put an ip address on my serial, what will it/not do ?
Re: serial, no ip address
It will not do IP processing. However if you want IP processing to be done on serial interface without using IP address use IP unnumbered command
so will the interface not be able to operate with no ip address ?
if u dont put petrol in your car what will happen it will not run so its simple the router will not be able to route or communicate.......but it can be possible still not putting ip address but can make it work its with ip unnumbered command.....
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8d.shtml
its a v goo dlink for understanding it cheers and rate all post plz
666
