Community Member
Serial Numbers
Please how can I determine the serial number of the fans and power supply on a Catalyst 4003 and 4006 running CatOS from the config?
Community Member
Re: Serial Numbers
I think only option is to unplug the modules and a visual checkup...
Purple
Re: Serial Numbers
Can't get that from the command line like other person said you would have to pull the components , only the newer IOS devices give command line capabitlity for that information.
392
