server load balancing (same mac address on multiple NICs)
podera
I believe that on UNIX operating system there is a way to configure multiple NICs with the same mac address and so realise a load balancing btw multiple interfaces. Is this something what would work in a cisco LAN infrastructure? Like two 3560s uplinked together, and both switches have one NIC with the same mac-address? (same VLAN)
ralphcarter
Your talking about NIC bonding. You cannot have the same mac-address tied to 2 NICs at once because you will create MAC Flapping on the switches. The only way to do this is to create an LACP bond with your NIC interfaces & the switch interfaces, but these have to be either stacked switches(3750G only) or 2 x 6500 in VSS configuration.
In your case with 2 3560's, you cannot run LACP to 2 different switches, you can however run LACP to a single switch and have 2-8 NICs connecting into this 1 switch, the LACP port-channel will see 1 mac-address that is basically shared between multiple NICs on the server.
NIC Bond Modes
Mode 0 - balance-rr
Single switch/stack configuration or multiple switch,create non-lacp etherchannels on switch
This also creates a lot of “out of order” packets and forces TCP congestion control to kick in because it balances a tcp stream.
Mode 1 - active-backup
Can use on multiple switches - best for High availability
Mode 2 - balance-xor
Single switch/stack configuration, create non-lacp etherchannels on switch
Mode 3 - broadcast
Multiple switch configuration or stack that is not trunked together and connects to outside networks
Mode 4 - LACP
Single switch/stack configuration , create lacp etherchannels on switch
Mode 5 - balance-tlb (transmit load balancing)
Mode 6 - balance alb (adaptive load balancing, both tx and rx)
If you plan on connecting into 2 different 3560 switches then you can use Mode 0,1,5,6
Note: Using mode 6, the “updelay” needs to be set to something equal or greater than the switches forwarding-delay, the cisco default forwarding delay is set to 15. Cisco value of 15 is determined based upon the STP Diameter traversing 7 switches to a layer 2 destination. If you change the spanning-tree diameter then you should change the “updelay” to this forwarding-delay.
Also, you cannot have "portfast" enabled on your bonded switch interfaces, portfast can be enabled with LACP, but you cannot use this in your config.
Hope this helps.
CCIE 26175
www.techsnips.com
ralphcarter
NIC Bond Modes
Mode 0 - balance-rr
Mode 3 - broadcast
Mode 4 - LACP
Hope this helps.
CCIE 26175
www.techsnips.com
