Bronze
Service password-recovery not in cli
Hello again!!
Is there a reason the "[no] service password-recovery" command is not available in the list of IOS commands?
I've looked at IOS 12.4- 15.x (IPBase through Advanced IP services) on the 2800 series routers.
The Cisco documtation states this command is available via CLI.
Back-in-the-day, hidden IOS commands carried all the talk and of course Cisco stated hidden commands were not supported.
The command works as expected on IOS 12.4 through 15.x BUT  just need to ensure MGT understands the resons why the command does not show itself.
REMOTE-SITE-1(config)#service ?
alignment             Control alignment correction and logging
call-home             Enable call-home service
compress-config      Compress the nvram configuration file
config                TFTP load config files
counters              Control aging of interface counters
dhcp                  Enable DHCP server and relay agent
disable-ip-fast-frag  Disable IP particle-based fast fragmentation
exec-callback         Enable exec callback
exec-wait             Delay EXEC startup on noisy lines
finger                Allow responses to finger requests
hide-telnet-addresses Hide destination addresses in telnet command
linenumber            enable line number banner for each exec
nagle                 Enable Nagle's congestion control algorithm
old-slip-prompts      Allow old scripts to operate with slip/ppp
pad                   Enable PAD commands
password-encryption   Encrypt system passwords
prompt                Enable mode specific prompt
pt-vty-logging        Log significant VTY-Async events
sequence-numbers      Stamp logger messages with a sequence number
slave-log             Enable log capability of slave IPs
tcp-keepalives-in     Generate keepalives on idle incoming network
                      connections
tcp-keepalives-out    Generate keepalives on idle outgoing network
                      connections
tcp-small-servers     Enable small TCP servers (e.g., ECHO)
telnet-zeroidle       Set TCP window 0 when connection is idle
timestamps            Timestamp debug/log messages
udp-small-servers     Enable small UDP servers (e.g., ECHO)
REMOTE-SITE-1(config)#no service password-recovery
WARNING:
Executing this command will disable password recovery me chanism.
Do not execute this command without another plan for password recovery.
Are you sure you want to continue? [yes/no]:
THANKS for any assistance
Frank
Hall of Fame Super Blue
Duplicate post.
Bronze
Re: Service password-recovery not in cli
Summary
Switch 2960 IOS ver c2960-lanbasek9-mz.122-55.SE.bin
Router 2801 IOS ver c2801-ipbasek9-mz.151-3.T3.bin
DETAILS
REMOTE-126S#sh ver Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2010 by Cisco Systems, Inc. Compiled Sat 07-Aug-10 23:04 by prod_rel_team Image text-base: 0x00003000, data-base: 0x01800000 ROM: Bootstrap program is C2960 boot loader BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1) REMOTE-126S uptime is 2 days, 22 hours, 19 minutes System returned to ROM by power-on System image file is "flash:c2960-lanbasek9-mz.122-55.SE.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco WS-C2960-8TC-L (PowerPC405) processor (revision C0) with 65536K bytes of memory. Processor board ID FHG1350R06Y Last reset from power-on 2 Virtual Ethernet interfaces 8 FastEthernet interfaces 1 Gigabit Ethernet interface The password-recovery mechanism is disabled. 64K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address      : 9C:AF:CA:A7:82:80 Motherboard assembly number    : 73-10611-07 Power supply part number        : 341-0208-01 Motherboard serial number      : FOC13491LH7 Power supply serial number      : LIT13410G01 Model revision number          : C0 Motherboard revision number    : D0 Model number                    : WS-C2960-8TC-L System serial number            : FHG1350R06Y Top Assembly Part Number        : 800-28132-02 Top Assembly Revision Number    : A0 Version ID                      : V02 CLEI Code Number                : COM8A00ARB Hardware Board Revision Number  : 0x01 Switch Ports Model              SW Version            SW Image                ------ ----- -----              ----------            ----------              *    1 9    WS-C2960-8TC-L    12.2(55)SE            C2960-LANBASEK9-M        Configuration register is 0xF !
Scottsdale-126R#sh ver Cisco IOS Software, 2801 Software (C2801-IPBASEK9-M), Version 15.1(3)T3, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2011 by Cisco Systems, Inc. Compiled Wed 14-Dec-11 21:20 by prod_rel_team ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1) Scottsdale-126R uptime is 3 days, 21 hours, 27 minutes System returned to ROM by reload at 21:40:47 UTC Thu Feb 9 2012 System image file is "flash:c2801-ipbasek9-mz.151-3.T3.bin" Last reload type: Normal Reload This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco 2801 (revision 6.0) with 354304K/38912K bytes of memory. Processor board ID FTX1033Y1JF 2 FastEthernet interfaces 1 Serial(sync/async) interface DRAM configuration is 64 bits wide with parity disabled. 191K bytes of NVRAM. 125440K bytes of ATA CompactFlash (Read/Write) License Info: License UDI: ------------------------------------------------- Device#  PID                  SN ------------------------------------------------- *0        CISCO2801            FTX1033Y1JF              Configuration register is 0x3922
576
