set spantree bpduguard command
mahesh18
Level 6
Level 6
hi all,
on Catos switch  what does command
sey spantree bpdu-guard 6/1-48 default mean?
my understanding is that it enables bpdu-guard globally on the module 6?
please let me know
thanks
mahesh
2 Accepted Solutions
Reza Sharifi
Yes, it would enable it on all ports on module 6.  You can also enable it globally (see below command) for all modules. It is disabled by default.
set spantree portfast bpdu-guard enable
Have a look at this doc for more info:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
Reza
Ganesh Hariharan
hi all,
please let me know
thanks
mahesh
Hi Mahesh,
set spantree bpdu-guard mod/port {enable | disable | default} ,If you enter the default keyword, the spanning tree port is set to the BPDU guard state globally.To enable or disable BPDU guard for all ports on the switch, enter the set spantree global-default bpdu-guard command.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Reza Sharifi
Reza
Ganesh Hariharan
hi all,
please let me know
thanks
mahesh
Hi Mahesh,
Hope to Help !!
Ganesh.H
