Community Member
setting bandwith catalyst 6509
How do i set the speed per port on the cat6509. I want to limit a port to 1.5 meg.
Re: setting bandwith catalyst 6509
Brad,
The ports are L2 ports or L3 ports.
You can use QOS policing and rate limiting for the same.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/qos.htm#wp1581776
HTH,
-amit singh
Community Member
they are layer 3
127
