setting default settings to 2960
I need to delete all running configuration on the switch. Could anyone tell me how to set C2960 to default settings?
1 ACCEPTED SOLUTION
Silver
Re: setting default settings to 2960
Hi!
Can you please mark the issue as solved?
Niranjan
Silver
hi!
You can "erase start" from previliged mode and restart the switch. It will bootup with default config.
Niranjan
thanks for ur reply,
I wrote "erase start" on EXEC mode then I entered "reload". After that switch's SYST link has been flushing(green) for 5 minutes, I dont understand what's wrong, I have unpluged and pluged the power cord, but syst link is still flushing and the switch does not work:( could u tell me what to do?
What does the console say? What output do you have on the console/ Is it stuck in ROMMON or something? Can you paste the consoe output?
Niranjan
I think I am stuck in ROMMON but I am not sure, when I connect the switch with console port, only "switch:" is written on the console.
when "?" is entered those output comes
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
sleep -- Pause (sleep) for a specified number of seconds
-- MORE --
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
when I unplug the power cord then I push the mode button and plug the power cord, after a certain time this output is appeared
switch:
Base ethernet MAC Address: 00:1e:f6:58:1d:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
The system has been interrupted prior to initializing the
flash filesystem. The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
flash_init
load_helper
boot
I have never seen this commands before, could u tell me the next step?
Silver
hi!
On the switch prompt, say dir flash:
if you see the ios image there, say boot flash:
this should boot it up.
For more info pls refer :
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Hope this helps (pl rate if it does)
Niranjan
Silver
if the switch is stuck in "Rommon " mode when you see through the console, probably it is not finding the boot image. See with dir slot0: or dir bootdisk: and once you get the image name, say boot bootdisk: or boot slot0:imagename depending on where the image is located.
Niranjan
I typed
switch: dir slot0
unable to stat slot0/: no such device
switch: dir
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
switch: boot bootdisk:flash (and tried with xmodem and null)
Loading "bootdisk:flash"...bootdisk:flash: no such device
Error loading "bootdisk:flash"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch: help boot
Usage for "boot" is:
boot [-n|-j] [-p] [-c] [-f] [-i] [-m] [-notnd] [-notni] [-post] [-skip_post]
[-reserve_mem <1-15>] [-no_esp_keepalive] []
I dont know what to do now, could u tell me what should I do ?
thank u so much for your helps
Purple
Do a "dir flash: and see if there is any image in there. If there is issue a "boot flash: command and see if it will boot other wise you will have to go thru a image recovery procedure . Doing what you did would not have erased the image file , someone else would have had to erase the file while it was powered up and you were the unlucky person who tried to erase the config.
I did it
switch: dir flash:
Directory of flash:/
32513024 bytes available (1024 bytes used)
there is no any image file. so what do I have to do ? I think I need to download 2960 IOS and load to switch, do u know where can I download 2960 IOS
Silver
hi!
You woul need a cisco.com login to download the image from under "software downloads" on the cisco main page.
Regrads,
Niranjan
thank you so much for your helps, I have solve the problem:)
Silver
Hi!
Niranjan
1906
