Setting source address of locally generated packets
I want to set the source address of ping packets to the loopback0 address by default.
I know that this can be done using ping in privilege mode, but can the router be made to send all locally generated packets from a specified interface address?
1 REPLY
Re: Setting source address of locally generated packets
Hi ,
use ip local policy route-map
Also , because you cannot change the source of the packets , you will have to do nat overload on the loopback.
int lo0
ip nat ouside
ip access-list extended acl
permit icmp any any
ip nat inside source list acl interface Loopback0 overload
route-map test permit 10
set interface Loopback0
match ip address acl
ip local policy route-map test
Dan
258
