02-17-2014 07:18 AM - edited 03-07-2019 06:15 PM
Good morning,
I'm setting up my home lab for an eventual CCNA certification and have purchased some routers and switches. I'm trying for a basic setup where I have a laptop wired to a switch, which is wired to a router, which is itself connected to a Bell DSL router.
Here are some specs:
Switch: 2950
Router: 2610XM
Bell Router: Alcatel Lucent 7130
Here are my Show Runs:
Switch:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Switch_1
enable secret 5 $1$vaA0$A26rMRzLqXPdI/48zElpt1
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
duplex full
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
ip address 192.168.10.1 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.2
ip http server
banner motd
SWITCH_1
line con 0
password 7 02050D480809
login
line vty 0 4
login
line vty 5 15
login
end
Router:
Current configuration : 3222 bytes
version 12.4
hostname Router_1
boot-start-marker
boot-end-marker
enable secret 5 $1$0XqM$WNMipOJUubUovb9qJs/911
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.3 192.168.10.99
ip dhcp excluded-address 192.168.10.151 192.168.10.254
ip dhcp pool INSIDE_LAN
import all
network 192.168.10.0 255.255.255.0
domain-name homestead.ca
dns-server 4.2.2.2
default-router 192.168.2.1
lease 3
ip domain name homestead.ca
crypto pki trustpoint TP-self-signed-1228350807
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1228350807
revocation-check none
rsakeypair TP-self-signed-1228350807
crypto pki certificate chain TP-self-signed-1228350807
certificate self-signed 01
3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31323238 33353038 3037301E 170D3032 30333031 30373334
30345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32323833
35303830 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100BE44 5DAC82C6 06D1A92C C5D39B63 19BF0DE6 956680FA A5E753D7 364C9A26
4D320F7C A3DF4660 23061EB3 CB0D9E50 A27FB5A7 337ECBE8 38364BFF 6761F4D1
2B61EFC3 B043FD26 A78067A0 11173C87 93EA9ACB FCD72545 8BC172EC 5C27905E
F276735C 7EDA0092 2A39C515 6D87564D 73AE94E9 4D0B9DE9 09EC5153 F89BCCEE
3DA70203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
551D1104 19301782 15526F75 7465725F 312E686F 6D657374 6561642E 6361301F
0603551D 23041830 1680146D A307E3B4 5834790B E13AB4B2 F8C15D8C B72C6330
1D060355 1D0E0416 04146DA3 07E3B458 34790BE1 3AB4B2F8 C15D8CB7 2C63300D
06092A86 4886F70D 01010405 00038181 00BA7A90 10657F35 F80E75E1 4DC0612F
976FBCEA A9B28242 A9CA9876 7EC6AE3F 113CDB78 90A112F5 B3ACF80A B42874C7
8342FFD2 8FEE5644 764F0A06 DFEFF664 B1B6C40B DE4D5A35 E979F742 F8A516E4
6B8B53DB A3852360 56230938 7E686CD0 DD767F8C 40CE9DEA 2ED576CE CAD8F3FE
665E9459 A845D15A A0C392F5 658CE1DA AE
quit
username marc privilege 15 password 0 cisco
interface FastEthernet0/0
ip address 192.168.2.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface Serial0/1
no ip address
shutdown
interface Ethernet1/0
ip address 192.168.10.2 255.255.255.0
full-duplex
interface Ethernet1/1
no ip address
shutdown
full-duplex
interface Ethernet1/2
no ip address
shutdown
full-duplex
interface Ethernet1/3
no ip address
full-duplex
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip http server
ip http authentication local
ip http secure-server
control-plane
banner motd%
Router_1
^C
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login local
transport input telnet ssh
end
The PC can ping the switch and both inbound/outbound ports of the router but cannot ping the DSL (192.168.2.1).
The Switch can ping the PC and both inbound/outbound ports of the router but cannot ping the DSL (192.168.2.1).
The Router can ping the Switch, the PC, the DSL and the outside (I used 4.2.2.2)
Suggestions?
Thank you.
Solved! Go to Solution.
02-17-2014 11:14 AM
Marc
The DSL needs a route back to the 192.168.10.x network. So using IOS terminology (although the DSL will have different syntax) -
ip route 192.168.10.0 255.255.255.0 192.168.2.2
if you cannot add a route to the DSL then the other option is to NAT all 192.168.10.x IPs to 192.168.2.2 so that DSL knows where to send teh return traffic eg.
int eth1/0
ip nat inside
int fa0/0
ip nat outside
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
ip nat inside source list 101 interface fa0/0 overload
Jon
02-17-2014 11:14 AM
Marc
int eth1/0
ip nat inside
int fa0/0
ip nat outside
Jon
02-17-2014 11:44 AM
Hi Jon,
Thanks for the help. I used NAT since I didn't want to mess what is admittedly a tempermental Bell router. Works like a charm.
Marc
02-17-2014 11:51 AM
Marc
No problem, glad to have helped
Jon
