10-20-2017 04:15 AM - edited 03-08-2019 12:26 PM
Hi Guys,
is it possible to use the SFP-10G-SR-S Module for the C3850-24XS-S with the IOS Version 16.6.1 (Everest) and any Network Module (4x10G, 8x10G) installed?
Thanks in advance for your help!
Mathias
Solved! Go to Solution.
10-20-2017 04:57 AM
Hi there,
The 16.6.1 release notes state that the network module is supported:
As for the SFP+, the compatibility matrix states that the minimum supported release is 3.7.1E which was the first image available for the switch, so you can infer that 16.6.1 will be supported:
cheers,
Seb.
10-20-2017 04:57 AM
Hi there,
cheers,
Seb.
10-20-2017 06:33 AM
Thanks for your help!!
