SFP consult
Recently I bought a WS-C3560TS-S and now I need a fiber SFP to link between switches (connect 2960 switches with 3560 switch) in a distance less than 200 meter, but I dont know wiech is the appropiate model to connect them. Can you help me to select It
Re: SFP consult
You can buy GLC-SX-MM SFP to connect the switches together.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
HTH,
-amit singh
Re: SFP consult
Following are the generally used fiber standards -
1000base-SX - Multimode Fiber Only
1000base-LX/LH - MMF + SingleMode
1000base-ZX - SMF only
1000base-SX can be used for distances up to 550mts.
go for the 1000base-SX SFP suggested in the above post with a MMF cable.
Compatibility list for future use - http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
-> Sushil
116
