Community Member
SFP modules to use on Catalyst 3650-24TD-E
We plan to buy a Catalyst 3650-24TD-E switchs, and I would like to be sur to buy the right SFP and SFP+ modules for it. As you know this Switch's model supports 2 1-Gigabit SFP and 2 10-Gigabit SFP+ uplink ports.
We have alrady other catalyst 2960 switchs with GLC-SX-MM SFP modules for the uplink connections.
which SFP/SFP+ models do you recommand?
Best regards,
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
GLC-SX-MMD
GLC-SX-MMD
Community Member
Thank you,
Thank you,
and for the SFP+ modules ?
If the 2960 is only using GLC-SX-MM then the 3650 cannot use SFP-10G-SR to link the two of them.  The modules need to be of the same speed and the same wavelength.
Community Member
We will buy 2 3650 that will
We will buy 2 3650 that will be a about 100m from each other. So it's better to connect them using 10G SFP I think!
155
