Community Member
SFP port protection
Hi There,
is there any kind of SFP port protection when there is no SFP connected to the port ?
I'm worry about creating some damage to does ports because they're open...
Thanks.
Andrei.
VIP Super Bronze
Re: SFP port protection
Andrei,
You can use port dust cover plugs to protect them.
Here is link to it:
http://www.cablesandkits.com/cisco-sfp-port-dust-coverplug-p-1672.html
Reza
Community Member
Thanks a lot !
5 point for you :)
Andrei.
Hall of Fame Super Gold
Hi Andrei,
Take the SFP module out of the appliance and put it into a non-static bag.
This will prevent any physical damage or theft ... or a phenomenon called "e-bay". ;)
173
