Community Member
SFP Ports on 3560
My Question is about the bandwidth that SFP Ports on a 3560 provide. There are four SFP ports on my 3560-48. Do these ports provide dedicated bandwidth separately ? Also do these ports share bandwidth with the other 48 UTP ports on the switch or the have separate dedicated bandwidth ?
Will appreciate the help.
Super Bronze
Re: SFP Ports on 3560
Can't find the diagram I'm looking for, but recall the 3560/3750 split the ports across 2 or 3 internal ASICs. Each port, I think, including the SFP ports, has gig but there is an oversubscription of the ports per ASIC and internal fabric.
Q. Are the Cisco Catalyst 3750G 48-port units oversubscribed?
A. Yes. There's a 52 to 32 Gbps oversubscription.
Q. What is the difference between the 3560G and the 3750G?
A. The 3560G SKUs are the standalone versions of 3750G. The 3560G SKUs do not implement the Cisco StackWise technology found on the Cisco Catalyst 3750 Series.
Q. What is the difference between the 4948G, 3750G, and 3560G 48 port units?
A. The 4948G is a full wire-rate box with a 96 Gbps, non-blocking, full-duplex switching fabric based on the Cisco Catalyst 4500 K-2 architecture, providing 72 million packets-per-second of switching capacity. It has removable redundant power supplies and a removable automatic variable speed fan tray. The 4948G series is also available with DC power supplies which aren't available on most 3750 or 3560 SKU's. The 3750G and 3560G 48 port units have oversubscribed switching backplane (52-to-32 Gbps oversubscription) and only have 1 power supply and fixed fan units. The 3750G units can stack together with other Cisco Catalyst 3750 Series or 3750G units using StackWise technology to form a single virtual switching unit. The 3560G is a standalone switch.
