06-17-2009 10:02 AM - edited 03-06-2019 06:19 AM
Does anyone know if you can install an SFP+ transceiver (SFP-10G-SR) like a regular SFP (GLC-SX-MM)in the twingig module on a 3750e? or do you have to go with the x2 for 10Gb? thanks.
Solved! Go to Solution.
06-17-2009 10:16 AM
Hello Brandon,
according to
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/hardware/install/notes/1757202.html
is not supported so you need an X2 format module to replace the twingig module
Hope to help
Giuseppe
06-17-2009 10:16 AM
Hello Brandon,
according to
Hope to help
Giuseppe
06-17-2009 10:30 AM
that's what i thought, but wanted to verify. thanks.
06-17-2009 12:30 PM
Hi.
The Twingig is explicitly made to change an X2 10Gbps port to two 1 Gbps SFP ports, so no.
HTH.
