Community Member
sg-300 acl vlan question
I have a SG300 Switche working in layer 3 mode.
I configured 3 VLANs on the switch with different ip's
Vlan 1: 192.168.1.1
Vlan 2: 192.168,2.1
Vlan 3: 192.168.3.1
Now I want to implement ACL to permit vlan2 to have full access on vlan3 but I want to deny access from vlan3 to vlan2
Is this possible and do you have an example?
Best regards
Andreas
Community Member
Hi Andreas
have you try to place ACL in outbound direction under the VLAN3 ....... which specifically deny the traffic from vlan3 (192.168.3.1) to vlan 2 (192.168.2.1) but allow all other traffic.
hope this will work
Dont forget to rate if its useful.
Salman Jamshed
Green
Re: sg-300 acl vlan question
Hi Andreas,
Log to the UI of the switch.
Navigate Access Control -> IPV4 Based ACL
Create the access list with the name you want.
Navigate Access Control -> IPV4 Based ACE
Select the name of your ACL then click ADD
The priority is very important. I recommend to do in increments of 10, so rule #1 priority = 10, rule #2 = 20, etc
Action is to DENY
Protocol = ANY
Source IP: 192.168.3.0 0.0.0.255
Destination IP: 192.168.2.0 0.0.0.255
Save this
Create second ACE rule,
Priority 20
Action PERMIT
Protocol = ANY
Source IP: Any
Destination: Any
Save
Lastly, you need to bind the ACL to a port.
Go to Access Control -> ACL Binding
Choose a port, edit it, choose the IPV4 ACL, apply it.
-Tom
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Community Member
Thanks Thomas for you answer. That is pretty much how I created the access list. My problem if I understand it correct is if I deny access from vlan3 in the vlan2 acls then I will have no access from vlan2 to vlan3 because the reply packages coming back from vlan3 will be filtered.
Thanks Salman for you answer too. What do you mean with "ACL in outbound" direction. What I understand is that the sg300 switch can only have ACL on the ingress traffic. So is there any possibility to see who started the ip conversation?
Thanks for your help
Andreas
Green
Correct, there is not an inside or outside, the ACL is applied ingress only. The switch logging should show if traffic dropped per the ACL.
-Tom
Community Member
Andreas, have you found the solution ?
VIP Purple
Hello
Option 1 (Not sure if this would deny traffic both ways if so see option 2)
Access-list 100 permit ip 192.168.3.0 0.0.0.255 any
Access-list 101 permit ip any any
Vlan-access map TST 10
Match IP address 100
Action drop
Vlan-access map TST 20
Match IP address 101
Action forward
Vlan filter-list TST 20
Option 2 ( tcp traffic initiated from vlan 2 would allow return top traffic from vlan 3)
Ip access-list extended TST
Permit tcp 192.168.3.0 0.0.0.255 any established
deny tcp 192.168.3.0 0.0.0.255 any
permit ip any any
Int vlan 2
Ip access-group TST out
Res
Paul
Please don't forget to rate any posts that have been helpful. Thanks.
Community Member
hi Paul the commands you presented unfortunately do not apply to SG500 switches ...
do you have "the same" set of commands for SG500 series ?
VIP Purple
hello
Whatabout option 2?
Res
Paul
Community Member
what is "option 2" ?
VIP Purple
Hello
permit ip any any
Int vlan 2
Community Member
hi there, my misunderstanding.
both options do not work.
there is no command "ip access-group X out" for an interface
VIP Purple
Hum, okay try this
permit ip any any
int vlan 3
service-acl input TST
Thanks.
Community Member
no luck.
SG500 does not recognize anything like "service-acl"
below set of availabe commands:
SG500(config-if)#service-acl
% Unrecognized command
SG500(config-if)#
  bridge               Bridge configuration commands
  do                   execute an EXEC-level command
  dot1x                dot1x protocol
  end                  Exit from configure mode
  exit                 Exit from current context
  help                 Description of the interactive help system
  ip                   Global IP configuration commands
  ipv6                 IPv6 commands
  name                 set vlan name
  no                   Negate command
  sntp                 Global Simple Network Time Protocol (SNTP)
                       configuration subcommands
SG500(config-if)#ip
  address              Set the IP address of an interface
  dhcp                 Configure DHCP services
  igmp                 Configure igmp interface.
  proxy-arp            Enable proxy ARP on interface
SG500(config-if)#do
  boot                 Boot Commands
  clear                Reset functions
  clock                Manage the system clock
  configure            Enter configuration mode
  copy                 Copy from one file to another
  crypto               Cryptographic commands
  debug-mode           Exit from the EXEC to debug mode
  delete               Delete a file from the flash file system
  dir                  Display the list of files on the flash file system
  disable              Disable privileged commands
  dot1x                802.1x EXEC commands
  exit                 Exit from the EXEC
  green-ethernet       Green ethernet commands
  login                Exit from the EXEC and Log in
  macro                Ports macros
  menu                 Enter into Menu-CLI
  more                 Display a file
  no                   Negate command
  ping                 Send echo messages.
  reload               Halt and perform a cold restart
  rename               Rename a file
SG500(config-if)#
VIP Purple
Re:sg-300 acl vlan question
hello
i dont have access ti cco documentation to check the ios commands for this switch
can you create the acl if so you must be able to apply it to an interface
res
paul
Sent from Cisco Technical Support Android App
2173
