sg200-26p power distribuition
I have the following problem.
As my client setup is, the only way to power ap´s is as follow:
Entry nº  Port      POE Administrative Status   Power priority Level  Administrative Power Allocation   Maxpower Allocation   PC     Class
1         GE1        Enabled                      Low                   15400                           16900                 0      3
2         GE2        Enabled                      Low                   15400                           16900                 0      3
3         GE3        Enabled                      Low                   15400                           16900              7200      0
4         GE4        Enabled                      Low                   15400                           16900                 0      3
5         GE5        Enabled                      Low                   15400                           16900                 0      3
6         GE6        Enabled                      Low                   15400                           16900                 0      3
7         GE13       Enabled                      Low                   15400                           16900             11900      3
8         GE14       Enabled                      Low                   15400                           16900                 0      3
9         GE15       Enabled                      Low                   15400                           16900              7500      0
10        GE16       Enabled                      Low                   15400                           16900                 0      3
11        GE17       Enabled                      Low                   15400                           16900              7600      0
12        GE18       Enabled                      Low                   15400                           16900                 0      3
Device     Local Interface  TTL   Capabilities            Platform Neigbor          Interface
 AP3        GE3             172    Router, Trans Bridge   cisco AIR-CAP3602E-E-K9   GigabitEthernet0.l
 AP7        GE13            172    Router, Trans Bridge   cisco AIR-LAP1142N-E-K9   GigabitEthernet0.l
 AP5        GE15            172    Router, Trans Bridge   cisco AIR-CAP3602E-E-K9   GigabitEthernet0.l
 AP1        GE17            172    Router, Trans Bridge   cisco AIR-CAP3602E-E-K9   GigabitEthernet0.l
My question is: how power distribuition is really done on those switches?
with actual setup, no power on GE1 or GE2, if you remove AP3 on GE3, GE1 or 2 power up devices.
Are 16900 divided between two or more ports?
I dind´t find the relevant answer on the switch specifications.
Can anyone help?
Everyone's tags (1)
11
