04-24-2018 01:18 AM - edited 03-08-2019 02:46 PM
have here a very strong behaviour, after pluging in a cable the switchport mode of a port is switched automatically to trunk (e.g. from general or access). How to disable it?
Henri
Solved! Go to Solution.
04-24-2018 01:39 AM
Disable "Smart switchport" setting for a port and check. What device are you going to connect?
Deepak Kumar
04-24-2018 01:39 AM
Deepak Kumar
05-02-2018 12:40 AM
Hi Deepak,
thanks a lot, this was most helpfull.
Best regards
Henri
