Community Member
'sh cdp ne' - Learning neighbors
3560-48PS (MechEng_PGrad_(A) switch is connected to the below switches using interfaces 0/46-49. All links are dot1q trunk links.
Basically from the output 'show cdp ne' on this switch, this displays switches which are not neighbors on this switch.
All "learned" links are ISL trunk links on the 6509 switch!
Please advise
G0/46 - xxxx-router WS-C6509
G0/47 - MechEng_PGrad_(B) WS-C3560G
G0/48 - MechEng_PGrad_(C) WS-C3560G
G0/49 - MechEng_PGrad_(B) WS-C3560G
1 REPLY
Hall of Fame Super Bronze
Re: 'sh cdp ne' - Learning neighbors
The 3560 switch is connected to some kind of Metro-Ethernet service on port 49? If so, the behavior is expected as many switches will participate in the same Vlan hence seeing each other via Layer2.
HTH,
__
Edison.
118
