sh logging output
vipinrajrc
Level 3
Level 3
Hi Experts,
I got an alert mail from one of my switches. From the logs i got the followings
2w0d: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed s
tate to down
tate to up
tate to down
tate to up
tate to down
tate to up
tate to down
tate to up
tate to down
tate to up
tate to down
tate to up
tate to down
tate to up
tate to down
tate to up
I checked whether there is any error in interface. But i couldnt find any excpet one interface reset.
What exactly is this? I hear about interface flapping. Is this due to interfce flapping?
What is mean my interface flapping? is it due to some faulty hardware in the switch or due to the ethernet conenction?
Please advice
Vipin
Thanks and Regards, Vipin
6 Replies 6
Hi Vipin,
Yes your fastethermet 0/1 has flapped.
It can be due to faulty hardware, fault cable or some issues in ethernet connection.
HTH,
Smitesh
Thank you for your reply
So why dot it report any error in " sh interface fa0/1" ? I am having simialr issue with fa0/7 also.
One more doubt, what is the number infornt of each line "2w0d"? does it mean that 2week 0day?
Vipin
Hi Vipin,
Is is why Don't or why do ?
Interface flaps are not displayed in the sh interface output. You will only see interface reset in show interface output; which can be due to interface buffers full, etc.
yes 2w0d is 2weeks 0 days and that is probably coming as you won't had configure NTP or date and time.
Smitesh
thanks for the reply.
i Didnt configure NTP.  yes i need to configure it.
Vipin
Hi Vipin,
If your concerned is addressed, Can you please close this thread.
So that other community member don't waste their valuable time coming to this thread and finding it to be already answered.
Smitesh
jimmysands73_2
Level 5
Level 5
I would change the cable and also try this doc if it flts your platform:
How to use Time-Domain Reflectometer (TDR)
https://supportforums.cisco.com/docs/DOC-18983
And on a side note I myself would add
to my config.
