Shape Average versus Shaped Round Robin Commands
What is the difference between these two commands on an interface as to how it does shaping? Can either be used to accomplish the same thing if I have a 100Mbps port speed with multiple VLANs on the port and I must shape to 10Mbps per VLAN to meet a contract the carrier Metro Ethernet service? The 3750 ME switch allows the shape average command to be used on the ES ports but I am wondering if the same shaping can be gained by using SRR.
1 REPLY
Re: Shape Average versus Shaped Round Robin Commands
SRR can be configred in shaped or shared mode. Shared will allow a class to use all available BW if it is unused by the designated class. Shaped mode will not allow this but performs a strict limit to each class queue.
I could not see the shape average command in the DOC CD command index for the 3750 and don't have one to play with to check!
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swqos.htm#wp1284809
1144
