Sharing a 10 mbps connection
caniculari
I have a Router 877 and a switch 3750 also a 10 mbps internet connection and I want to share the internet connection to 5 different vlans with a maximum of 2mbps each one or 2 mbps guaranteed. The switch and the router are connected for a trunk port and the vlans are defined in both devices. I have tried many configurations of this with no succes.
Can you tell me if this is possible? which could be the best guidelines to configure.
Thanks (Sorry for my english)
Leo Laohoo
5 different vlans
What IOS is your router running?
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T12, RELEASE SOFTWARE (fc3)
12.4(15)T12
This is going to be an issue.  870 will only support up to 3 VLANs (VLAN 1 included) if you are running IOS version 12.4.  If you want to run up to 10 VLANs (VLAN 1 included) then you need to downgrade the IOS to version 12.3.
For the record...
I try the next example and it works...
ip access-list extended VLAN1
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended VLAN2
ip access-list extended VLAN3
ip access-list extended VLAN4
ip access-list extended VLAN5
class-map match-any VLAN1
match access-group name VLAN1
class-map match-any VLAN2
match access-group name VLAN2
class-map match-any VLAN3
match access-group name VLAN3
class-map match-any VLAN4
match access-group name VLAN4
class-map match-any VLAN5
match access-group name VLAN5
policy-map CBWFQ
class VLAN1
  bandwidth 2000
class VLAN2
  bandwidth 2000
class VLAN3
  bandwidth 2000
class VLAN4
  bandwidth 2000
class VLAN5
  bandwidth 2000
policy-map SHAPING
class class-default
  shaping average 10000000
  service-policy CBWFQ
interface FastEthernet0/0
description TO INTERNET
service-policy output SHAPING
At the end it wasn't necesary to put 5 VLANS only two.
Thanks anyway
