Webcast-Catalyst9k
sharing per-packet unsupported?
why is load-sharing per-packet unsupported in 12.2(25)? Is there a replacement?
thx
best regards
Re: sharing per-packet unsupported?
Are you referring to ip cef load-sharing per-packet, or are you trying to tweak the etherchannel load-balancing method? Do a "show ver" so that we can see the exact version of IOS you're running (it may be a limitation of standard versus enhanced image), and the actual command you're typing in.
I mean the interface configuration command "ip load-sharing per-packet".
I found this:
|Unsupported Interface Configuration Commands
|ip load-sharing [per-packet]
Source: http://www.cisco.com/en/US/partner/products/hw/switches/ps646/products_configuration_guide_chapter09186a00802cb7e4.html
show version:
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(25)SEE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 03-Feb-06 07:59 by antonino
Image text-base: 0x00003000, data-base: 0x0123D8D4
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWARE (fc1)
DRSSWT001 uptime is 24 weeks, 2 days, 12 hours, 42 minutes
System image file is "flash:/c3750-advipservicesk9-mz.122-25.SEE.bin"
best regards,
Okay, so that's ip cef load-sharing that you're talking about. I agree that the command "ip load-sharing" just doesn't seem to be there. It doesn't matter if the 3750 IOS is IP BASE or IP ADVANCED. It doesn't matter if CEF is on or not, or if the 3750 is "ip routing" or not. I just checked, as we run all of these flavors in our environment.
That all tells me that the command not being there is a platform limitation. I did find something interesting, though. It appears that you can tweak the load-balancing for CEF using this command:
ip cef load-sharing algorithm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fswtch_r/xrfscmd2.htm#wp1062329
However, the subsequent keywords are not "per-destination" and "per-packet". Take a look, as it may have an impact on whatever the problem is that you're trying to resolve.
174
