Webcast-Catalyst9k
Sharing VLAN ports
Is it possible to share ports among different VLANs for Catalyst 2960? If so how?
3 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: Sharing VLAN ports
Hello Jamal,
I guess you would like to have multiple vlans on the same port.
This is called a trunk port
example:
int f0/5
switchport
switchport enc dot1q
switchport mode trunk
switchport trunk allowed vlan 10,20,30
this puts port fas0/5 in vlans 10,20,30.
be aware that device that connects to this must be able to understand the so called vlan tag and to agree on the list of permitted vlans.
Hope to help
Giuseppe
Hall of Fame Super Gold
Jamal
Yes the other suggestion is to change the interface config from:
switchport mode access
to
Rick
Hello Jamal,
if switchport enc dot1q is not supported it means that C2960 like C2950 supports only dot1q.
Don't worry about this.
as Rick has noted you need the
switchport mode trunk to make the port acts as a trunk
Hope to help
Giuseppe
Hello Jamal,
example:
int f0/5
switchport
Hope to help
Giuseppe
Hi Giuseppe,
I don't have the "switchport encapsulation dot1q" as a command option.
I still am not able to put a phyical port on two seperate vlans. Here is what the running configuration had for my port.
Int gb 0/5
switchport access vlan 10
switchport trunk allowed 10, 20
I'm not sure how to grant access to vlan 20.
If enter "switchport access to vlan 20" for that port, vlan 10 is no longer on the access list. It almost as if I can only assign one port to only one vlan.
I can't get port 5 to be on both vlan 10 and 20.
Any other suggestions?
Jamal
to
Rick
Hello Jamal,
Hope to help
Giuseppe
126
