Webcast-Catalyst9k
sho ver of cisco 3745
my cisco 3745 shows following output when done 'sho version'... this is part of the whole output....
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31744K bytes of ATA System CompactFlash (Read/Write)
Does that show that the router's flash can be increased using a separate flash card or a new card of capacity more than present card.....?
--gaurav
Re: sho ver of cisco 3745
HI Gaurav, [Pls Rate if HELPS]
If you are going to Upgrade the Router with New Verion of IOS Software which is larger in Size where the current FLASH Card is not compatible enough, the only Option is to replace the FLASH Card as "new" with higher capacity.
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Guru prasad,
Thanks for the quick response....
In which building/office are you in HCL comnet? just asking...
I'll definitely rate this response...
--gaurav
HI Gaurav, [Pls RATE if HELPS]
Sorry to say, starting from Jan 08" i work for a different Service Provider Company and no more with HCL Comnet Limited. But my "profile" is still not edited....
You can refer my E-mail ID and Mobile N0# available in my Porfile.
Pls RATE the informative POST
Best Regards,
Guru Prasad R
156
