Short interface bounces
Hi, I've noticed interfaces bouncing for just a few seconds. I can only see 5 crc and 5 input errors. Would this be enough for inteface to bounce?
Has anyone seen something like this? Bounce for just a few seconds?
Dec 11 12:58:13.312: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/40, changed state to up
Dec 11 12:58:31.984: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/40, changed state to down
Dec 11 12:58:33.992: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/40, changed state to up
Dec 11 13:06:52.816: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/40, changed state to down
Dec 11 13:06:57.104: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/40, changed state to up
Dec 11 13:07:16.016: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/40, changed state to down
Dec 11 13:07:18.024: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/40, changed state to up
1 REPLY
Re: Short interface bounces
Hi, CRC and input errors usually result from a layer 1 problem. I would check my cables for proper connections or even replace if needed. I would also check the speed and duplex settings on boths ends. I seen this happen in our network and the CRC and input errors just increased untill the problem was corrected.
WARNING: The CRC error rate is 0.66382% (greater than 1 in a million packets),
and the collision rate is less than 0.1%.
This can indicate excessive noise or transmission problems on the LAN or the LAN
bus itself. A high number of CRCs is usually the result of collisions or a station
transmitting bad data.
TRY THIS: Check cables to determine whether any are damaged. If 100BaseTX is being
used, ensure Category 5 cabling is being used and not another type, such as Category
3.
REFERENCE: For more information, see:
Troubleshooting Ethernet
Troubleshooting Ethernet Collisions
230
