Should IP accounting work on 3750 switch configured to route?
I have a 3750 that I'm using as a router:
"ip routing"
..and "no switchport" on the routing interfaces.
I added "ip accounting output-packets"
on both the interfaces setup for routing and ran a bunch of traffic through the device. But "show ip accounting" gives me nothing.
This seemed to work so easily on my 2821 router. Is there something about this being a switch that messes with accounting? Is there an alternative? Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: Should IP accounting work on 3750 switch configured to route
Sorry, ip accounting is not supported under Catalyst switches.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swuncli.html#wp1060469
HTH,
__
Edison
Please rate helpful posts
HTH,
__
Edison
Thanks for the reply!
Too bad they can't remove unsupported commands.
406
