show cdp neighbor details; entry address
Is there any criteria used to select the Entry address in show cdp neighbor details?
thanks
Devang Patel
1 REPLY
Bronze
Re: show cdp neighbor details; entry address
show cdp neighbors
To display detailed information about neighboring devices discovered using Cisco Discovery Protocol, use the show cdp neighbors command in privileged EXEC mode.
show cdp neighbors [type number] [detail]
Syntax Description
type (Optional) Interface type that is connected to the neighbors about which you want information; possible valid values are ethernet, fastethernet, gigabitethernet, tengigabitethernet, port-channel, and vlan.
number (Optional) Number of the interface connected to the neighbors about which you want information.
detail (Optional) Displays detailed information about a neighbor (or neighbors) including network address, enabled protocols, hold time, and software version.
Usage Guidelines
The vlan keyword is supported in Catalyst 6500 series switches that are configured with a Supervisor Engine 2.
The port-channel values are from 0 to 282; values from 257 to 282 are supported on the call switching module (CSM) and the firewall services module (FWSM) only.
494
