show errors on switch interfaces using a filtered view?
Andy White
Level 3
Level 3
I'm trying to get a list of errors on our switch interfaces, I thought this filter would work but it does show the interface name:
show interfaces | inc fastethernet | errors
     0 output errors, 1 interface resets
     0 output errors, 2 interface resets
     0 output errors, 0 interface resets
Leo Laohoo
sh interface | i line protocol|errors
7 Replies 7
Leo Laohoo
Thanks how can I redirct this to tftp?
sh interface | i line protocol|errors| redirect tftp:/192.168.90.11/errors.txt
The "redirect" option is one big fat bug.
The only way is to redirect the output to a text file in the appliance's flash and copy the text file to the TFTP server.
Well I can't argue with that lol
sh interface | i Ethernet[0-9]| reliability [^255]/[^255], txload 1/[^255], rxload 1/[^255]|Last input never|output never|Total output drops:_[^0]|[^0]_CRC|[^0]_unknown protocol drops|[^0]_late collision|[^0]_lost carrier|[^0]_output buffer
Try the above one and see if you'll find it interesting.  This one will filter out VLAN interfaces so you'll get physical interfaces.
Direct the output to a file located inside the appliance's flash using the command "COMMAND | redirect BLAH.txt".
Copy the text file from your appliance's flash to your TFTP server using the command "copy flash:blah.txt tftp://<TFTP IP address>".
In CRT just use the transfer menu option to receive the output which saves it to a text file
