show interfaces | include input errors
pverstegen
Does anyone know if there is a IOS command which displays all interfaces on a switch which contain input errors?
Regards, Peter
2 Accepted Solutions
You can adjust your | command to include the interface.
sh int | i Fast|input errors
Leo Laohoo
Hi Peter,
If you want the output which shows the interface and any line errors for the 6500 (IOS), try the command show interface counter error.
Does this help you?
6 Replies 6
Collin Clark
Your subject line works!
SW#sh int | i input errors
yes, but it doesn't show the interface numbers. What I actualy need is a method to show all interfaces in a specific vlan containing input errors in a campus network of about 40 Cat.6500 switches.
I can use Kiwi Cat tools for it, but I need an effective IOS command to check for. Regards, Peter
Leo Laohoo
Hi Peter,
You can also use the command "sh controllers ethernet-controller ".
Hope this helps.
Leo Laohoo
Hi Peter,
Does this help you?
Leo Laohoo
Thanks for the ratings, Peter.
