Community Member
Show mls stat on VS-S720-10G
we build with two VS-S720-10G a vss cluster. (IOS 12.2.18sxi1)
with the command "sh mls stat" we see the following output
Statistics for Earl in Module 1/5
L2 Forwarding Engine
Total packets Switched : 64979858519
L3 Forwarding Engine
Total packets Processed : 62896222161 @ 73933 pps
Total packets L3 Switched : 9083159444 @ 14122 pps
Total Packets Bridged : 53335574012
Total Packets FIB Switched : 9083159443
Total Packets ACL Routed : 0
Total Packets Netflow Switched : 1
Total Mcast Packets Switched/Routed : 213175557
Total ip packets with TOS changed : 2
Total ip packets with COS changed : 2
Total non ip packets COS changed : 0
Total packets dropped by ACL : 0
Total packets dropped by Policing : 0
Total packets exceeding CIR : 0
Total packets exceeding PIR : 0
Errors
MAC/IP length inconsistencies : 0
Short IP packets received : 0
IP header checksum errors : 0
TTL failures : 32
MTU failures : 0
Statistics for Earl in Module 2/5
Total packets Switched : 142254794779
Total packets Processed : 118283031493 @ 134415 pps
Total packets L3 Switched : 5811364099 @ 11453 pps
Total Packets Bridged : 112155371130
Total Packets FIB Switched : 5811364098
Total Mcast Packets Switched/Routed : 309736806
Total packets dropped by ACL : 15160
Errors
TTL failures : 17
MTU failures : 0
Total packets L3 Processed by all Modules: 181179253654 @ 208348 pps
We want to understand the meaning from that output
Could someone explain the Counters
thanks
1 REPLY
Hall of Fame Super Silver
Re: Show mls stat on VS-S720-10G
Hello Stephan,
the show presents the statistics for multilayer switching activity on the VSS node.
the meaning of the different counters should be the following:
total packets processed: total number of packets processed including L2 switching and L3 switching.
Total packets L3 Switched : packets that required a L3 action = packet rewrite moved from one vlan to another = routed packets
Total Packets Bridged: L2 frames moved within a single Vlan; frames are left unmodified (transparently bridged)
Total Packets FIB Switched:
of all L3 processed packets this number says how many have been processed by CEF FIB table in your case all L3 packets-1
FIB tables = CEF Forwarding Information Base tables
this is good means CEF based MLS is working well.
Hope to help
Giuseppe
373
