09-14-2017 10:48 AM - edited 03-08-2019 12:02 PM
I have a fex port E103/1/10 , but when i use show fex or sh int E103/1/10, i can't get port vsan or port WWN number, how to show vsan id and WWN number of the port
09-14-2017 11:03 AM
What model FEX do you have?
Does it support FC or FCOE?
09-15-2017 07:11 AM
09-15-2017 08:51 AM
So, do you see the port is configured and part of vsan?
"show vsan xx membership" should show you that.
09-18-2017 12:57 AM
Hi, if i type that command, it comes out fc interface fc1/5, and vfc interface vfc1020, what's the difference between these two? can fc port and vfc port both connected to san switch, or should they connect to storage? how would i know what are interfaces assigned to fc1/5?
09-21-2017 02:14 AM
can anyone explain difference between fc and vfc interface in show vsan membership?
