Community Member
show ver
Will the show version cpmmand show the correct serial number on a IOS router?
Re: show ver
unfortunately no.. it shows the processor /mother board ID and many other useful info.. on recent modular switches, u can see the serial nos of the chassis/line card using this command, but not with routers....
Hope this helps..
Raj
Re: show ver
you can see serial nmber of router at the back panel of chassis.
also try using "show diag" command, it will tell serial number of modules but i guess for few router models, it will give chassis serial number too.
rate if it helps ....
148
