Community Member
Shut down ports not in use for a specified time frame. sl_suspend_ports.tcl script is not working.
Dears,
I am trying to use the scripts sl_suspend_ports.tcl and  tm_suspend_ports.tcl as attached. I have taken these scripts from this Cisco forum. However tm_suspend_ports.tcl script is working absolutely fine. But it seems sl_suspend_ports.tcl ssripts is not working, it is not removing the up ports from suspend_ports. I have tested the below scenario, I am seeing that sl_suspend_ports.tcl is not working. Please find the scenario below.
I am running the scripts in an 8 port Cisco 3560 switch. I made not shut all the ports. As of now all the ports are enabled,, but  not connected with any devices. I confiured the suspend_ports_days as 2.
Day-0
Script ran at 00:00 time, stored all the inactive ports in suspend-port
Day-1
Script ran agian at 00:00 , again stored all the inactive ports in suspend_port.
Note:- I enabled fast ethernet 0/6 switch port after ran this script, after then made this port down. One syslog has been auto logged for this by saying that this port was enabeld and down.
day-2
Script ran again at 00:00 time, it disabled all the port.
Ideally it should not be disable the port Fast ethernet0/6 as I enabeld the port on the first day after ran the script. I think sl_suspend_ports script is not working,  as per my understanding this script should monitor the syslog port up message and remove this  interface from suspend_port file. I attached both of the script below. Kindly let me know how to achieve this syslog up message tracking.
141
