Webcast-Catalyst9k
Shutdown entry for Cat 6500
Is there any entry available to shutdown Cat 6500 chassis.
1 REPLY
Hall of Fame Super Blue
Re: Shutdown entry for Cat 6500
No you can't. You can reload modules individually, you can turn off power to individual modules, you can shutdown some service modules and you can reload the entire switch but the only way i know off to shutdown the 6500 chassis is to power it off manually.
Jon
297
